"ptcstatus" Fails
Creo 2, M230
When I open a command prompt and try to run "ptcstatus" I get this:
'ptcstatus' is not recognized as an internal or external command,
operable program or batch file.
I've never had issues with that before, how do I fix it?
TomU
TomUAnswer
Either run it from the directory ptcstatus.bat is located in (bin directory) or add the bin directory to your Windows PATH environment variable.
TomU
TomU23-Emerald IVAnswer
I added it to my path variable and all is good.
I've never had to do so before with any other install, any idea why the install would fail to do it automatically?
TomU
No, I don't know why.  None of the more recent versions seem to modify the PATH variable anymore.
