3-Newcomer
June 26, 2014
purge old versions in creo in a base directory and all of its sub folders
I currently have a right click context menu set up for the creo purge command. it works but i have 1400 folders to go through.
is there any way to purge old versions for creo in a base directory and all of its sub folders by running the purge command once?
FPerezAnswer
HELLO,
For a recursive purge you can use the script below :(change the foders settings)
Else i know that there are freewares on internet to do this.
@echo off
REM set to location of this script
set scriptname=C:\cao\temp\purge_all.bat
REM set to pro/engineer loadpoint
set prodir="C:\CAO\appli\Creo 2.0\Parametric"
if "%1" == "purge" goto p2
cls
call %prodir%\bin\purge.bat
echo.
FOR /D /R %%a IN (*.*) DO call %scriptname% purge "%%a"
:p2
cd %2
echo Purging %2.
echo.
2-Explorer
June 26, 2014
I use a free utility that works well, but is not very intuitive to use. It was written by a German guy/gal(?) and the interface is awkward. But it does purge old versions recursively (into sub folders) and it cleans out files like .logs and .inf and .m_p, etc...
proe dot cad dot de/downloads/DrPurge.html
I am sure there are others - maybe someone will post a better solution for us both!
-Nate
2-Explorer
June 26, 2014
why am I being moderated today?
"This reply has been hidden. This can happen if the message has been hidden by a moderator, or has been reported as abusive."
Here is a cleanup batch file. It will only do one folder at a time though. You put it in your folder and double click on it. I don't know how to edit such a file, but this is what it looks like in Notepad. Maybe there's way to edit it so that it can search in subfolders as well?
del *.ICON
del *.rpt
del *.alias2iges
del *.iges2alias
del *.step2alias
del *.alias2step
del *.m_p
del *.bom.*
del *.ger
del *.inf
del *.inf.*
del *.log.*
del *.lst
del *.lst.*
del *.memb
del *.ptd
del *.rel
del *.tst
del *.err
del *.ICON
Del *.LOG
Del *.idx
Del *.xml
purge.bat
2-Explorer
June 26, 2014
proe.cad.de/downloads/DrPurge.html
-Nate
Sorry for the double post - for some reason I am being "moderated" today.
FPerez13-AquamarineAnswer
HELLO,
@echo off
cls
echo.
:p2
cd %2
echo Purging %2.
echo.
3-Newcomer
June 27, 2014
just to clarify, could i create this as a batch file and/or run it from a right click context menu outside of creo?
Yes, this works fine exactly as you say.
I've actually had it set up as a right-click menu option on a folder in Windows, so you can right-click a folder and just purge it from there.
We had that version purging just the single folder, with another batch file which we ran from the command line to do a recursive purge - reduces the risk of an accidental click purging the whole drive!
2-Explorer
June 26, 2014
there is a free utility that I use - probably constructed with similar code as is shown above. The utility is written by a German individual and its interface and usibility is not the greatess - prett hard to figure out. But it wirks well and I use it regularly. It is called "Dr. Purge" and I think posting a URL get's my reply "moderated" and does not post. A google search for "dr purge" returns several direct references to this utility.
I used to use "SpekanPurge" which worked well, but lost the link to it and found Dr Purge...
Anyone use other utilities that work well?
-Nate
on Olaf Corten's site he has a purge tool, it is similar to what I already made myself, so I don't use it. But it appears to have a purge sub directories right-click.
