3-Newcomer
Query Related to Rathi transpower
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
Hello sir,
I need to one help from your side.
I have import the company logo using paintbrush in format. but how to lock the aspect ration when importing time.
One more i have created format in that i have import sketch logo.
When using this this frm in drw geometry color and sketch color is same , can we set using pentable in different color.
tbraxton
Follow the process documented here in the help files to import an image that you can then trace over to create what you need in Creo.
About Images (ptc.com)
joe_morton
Is this for the title block in a drawing?
Try this: https://www.ptc.com/en/support/article/CS160965?source=search
I've used the method described here: https://www.ptc.com/en/support/article/CS79011
The aspect ratio is locked and you can resize by changing the font size (if I remember correctly).
