Question creo2 old show/erase
we are in a creo2 update class
once we erase an axis is there a way to show the axis again?
is the only setting in the drawing.dtl?
is there a config option that allows us to show previously erased axis?
thanks bunches!
Terry
I think you need to ‘Delete’ the axis first (Not the real delete, which is forever) then you can show it again.
2-Explorer
July 24, 2014
I think I remember that you need to use the tree - expand the views and RMB
on the hidden item - this was a learned lesson for me with dimensions - I
assume that axes are the same? Sorry I cannot try it right now.
-Nate
You must bring them back from the new drawing tree.
With the new Creo behavior it is best to always delete dimensions instead of erasing them.
There are a couple of options available to automatically delete erased dimensions and axes. Enter the values in the Detail options (File > Prepare > Drawing Properties > Detail Option).
user_command delete_erased_dimensions
user_command delete_erased_axes
