Re: Method Server not starting
As per this thread - same issue
Hello. After installing Eclipse, I encountered a similar error, I tried your solution, but it didn't work. The error I get when I type windchill start in windchill shell: warn wt.manager.ServerLauncher - Starting Servermanager .
the error is so much, is there any solution you can suggest me?
