Reg: Model Check Batch Mode in windows
Hello Buddies
Good Day!!
Hope every one doing fine. I am using Pro/E Wildfire 3.0. I have succesfuly configured model check in interactive mode.
I am about to run a Modelcheck on some thousands of files. Going through on ptc help and the good article from ProfilesMagazin i decided to run modelcheck in batch mode. I use windows platform.
So that i have created a list of files using the dir *.prt.* *.asm.* *.drw.* /b > list.lst Then searched to the installation directory /bin. From there i have run modelcheck.bat. Modelcheck window appeared and i choosed "Batch mode" and browsed for the previously created list.lst file. Nothing happened.
It seems I did not get any model check out put report in my current directory. I am not sure Where I did mistake.
Kindly go through my attachment and help me to slove this issue Any help will be appreciated.
Suganthan.R
