May 9, 2011 1:49 PM UTC
Removing Intralink parameters
All,
I am trying to see if there is a config.pro option or something that I am missing. We are no longer using Intralink and I want to have copied files remove some of the Intralink parameters. When you do a Pro/E Save A Copy on the part the parameters are deleted. If you do a Pro/E Save A Copy on an assembly and pick a part to copy the parameters are not deleted. I have looked through the config options but have not been able to find anything. Thanks
May 12, 2011 2:42 PM UTC
All,
Sorry for the late postings on this. I got four responses three of them said use model check. The other suggested a tool called
May 13, 2011 2:59 PM UTC
Steve,
ModelCHECK does have the ability to remove unwanted parameters by adding the following options to the start configuration file:
PRT_PARAM_UNWANTED [parameter name]
ASM_PARAM_UNWANTED [parameter name]
DRW_PARAM_UNWANTED [parameter name]
I think this should help you achieve what you are looking for. More information can be found in the Help Topics collction document.
Rosemary
May 18, 2011 8:15 PM UTC
Does this also work for parameters that are locked, or that have been carried over from legacy data?
