Removing "On-Demand Simp Rep" text from Assembly Window
Our team really wants to be able to turn this text off when working in Assembly mode in Creo Parametric 3:
I have dug through Config.Pro options for hours, and I can't seem to turn this off!
Does anyone know how to remove this text display/overlay from the Assembly Window?
Thank you in advance!
I think you cannot remove unwanted text from graphic window.
From PTC Tecnical Support:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110248&art_lang=en&posno=3&q=graphic%20window%20text&source=search
Resolution
  • Reported to R&D as SPR 1984800.
  • Not part of the Pro/ENGINEER, Creo Elements/Pro and Creo Parametric functionality
  • For Dimension Tolerances:
    • In Pro/ENGINEER Wildfire and Creo Elements/Pro, View > Display settings > Model Display > General, uncheck option Dimension tolerances
    • In Creo Parametric, File > Options > Entity Display, uncheck option Dimension tolerances
  • For view states, refer to workarounds:
    • Method 1:
        • Temporarily hide:View > Shade
        • ​Display:View > Repaint
      • ​In Creo Parametric,
        • Temporarily hide:View > Model Display > Temporary Shade
        • ​Display:Graphics Toolbar > Repaint
    • Method 2:
      • In Pro/ENGINEER Wildfire and Creo Elements/Pro, the color of the texts is controlled by Hidden Line, click  View > Display settings > System Colors > Graphics. Change the color of Hidden Line to the same color of Background and uncheck option Blended Background
      • ​In Creo Parametric, the color of the texts is controlled by Secondary highlight, click  File > Options > System Colors > Graphics. Change the color of Secondary highlight to the same color of Background
Hello, The theme is quite old, but let me refresh it. As far as the presented solutions are applicable to single screens, what about animation? These subtitles are still visible in animations. Can I turn them off permanently?
Marcin
Did you ever find a fix for this? I have the same issue while making an animation, I would like hide the "simp rep: default REP" text.
Temporary shade doesn't work.
Google led me here!
