Feb 3, 2013 9:28 PM UTC
Replace by unrelated - Remember These
WF4, M190
I think I may have made a mess.
When replacing by unrelated component in WF4, there's a check box to 'Remember these components.'  I recall that this creates some kind of connection between the two, a bit like an interchange assembly.  I also believe there is a config option to turn that off (clear the checkbox) by default.  I thought I had set it, but it seems that I had not since it's coming up checked by default.
I've made quite a few replacements in my database, and I fear that I've created a bunch of unwanted relationships.  Is there a simple way to look for those and clear them and if so, where would I look?
Also, what is the config option to turn it off?
We do not have Intralink or PDMLink.
Feb 4, 2013 5:56 PM UTC
Thanks.  I looked in the GRV for external references on an assy where I know I made replacements and didn’t see any, so maybe I’m OK.  We’ll see.
Interestingly, I had added that config option to our config.sup for WF, Creo1 & Creo2 but not WF4.  It’s in there now.
Anyone know if this is something that was added to a later maintenance build of WF4?
