3-Newcomer
Mar 6, 2013 5:28 PM UTC
Resolve mode - Redefine, Reroute and Delete Grayed out
We just switched to Creo 2.0 this week. I have an assembly that a revolved protrusion within a component of the assembly fails, it can't find the centerline. Others at work are seeing this same issue as well. When I get into Resolve/Failure mode and try to do a Quick Fix on it to redefine the feature to fix the centerline issue, Redefine, Reroute & Delete are grayed out. My only choices are Suppress or Clip Suppress. From there I can open the component and redefine the feature, regen go back to the assembly and resume everything. Is there a config option that I need to set to give me the Redefine, Reroute and Delete options again?
Creo 2 M030
Windchill 10.0 M040
Ted Otto
