Dec 26, 2013 2:15 PM UTC
Right-click and middle mouse button does not work.....
I originally had Wildfire 5 on a seperate computer. I recently upgraded to Creo 2.0 on a seperate laptop and for some reason the right-click and middle mouse button will work for about 30 minutes, but after, my right-click and middle mouse button stop working.. I am not sure if this is a Creo issue or an issue with my laptop. I've messed with the mouse settings on my laptop, not sure how to change the mouse settings in Creo.
Frustrating...I've been trying to fix this issue for weeks...
Dec 26, 2013 5:51 PM UTC
Thats not an issue I have ever seen or heard of in Creo. Sounds more like you are having an issue with your computer or you mouse. Seems odd that it would for awhile then just stop.
Basic IT recommendations would be, restart your computer, get a different mouse. I'm guess you've already done those.
Dec 26, 2013 5:55 PM UTC
Yeah, I've done that. After I've restarted my computer, the buttons work. However, after about 30 minutes, the buttons no longer work.
Dec 26, 2013 6:05 PM UTC
Do the buttons stop working for all programs or just Creo? If they stop for all programs it might be a hardware issue, if the touchpad ribbon cable is not connected securely or properly, I could see this happening. If you feel confident enough to try a repair yourself ,remove the key board then the palmrest and finally remove and resecure the ribbon cable on the touchpad . Sometimes it's as simple as that.
Jan 9, 2014 1:15 PM UTC
I have the same issue...It is Creo 2.0 that is the issue. Restarting Creo clears it up. I also seem to lose preselection. Very frustrated with Creo 2
Mar 28, 2014 12:59 PM UTC
I've had a similar issue (I'm new to PTC/ProE) and I've just discovered that you just need to click and HOLD the right mouse button. For some reason, the single RMB click does not work like in any other software...
Mar 31, 2014 11:12 AM UTC
It works like that, because right-click in graphics window switches preselection highlighting to next available item (feature, geometry, etc.). That way it leaves click and hold in graphics window to show shortcut menu. Right-click in model tree gets you shortcut menu immediately.
