Running CREO 3 and 4 on windows 10
I can not run the Creo 3 and 4 on Windows 10. Could someone help me to solve this problem?
    startup problems are usually related to:
    1.] graphic card drivers
    -OR-
    2.] virtual network cards
    Case 1.]
    Open CREO3_LOADPOINT\Creo 3.0\Mxxx\Common Files\text\config.pro file in Wordpad and add following option at the end of the file:
    graphics  win32_gdi
    Then try launching Creo.
    Case 2.]
    Goto C:\ProgramData\PTC\Licensing directory. This directory is used as location for saving license file. Upload licence files to your reply - I will check the contents of them.
    Open DOS prompt window and run following command:
    ipconfig /all > ip.txt
    Upload ip.txt file to your reply - I will check the contents of it.
    Also upload CREO3_LOADPOINT\Creo 3.0\Mxxx\Parametric\bin\parametric.pf file - I will check the contents of it.
    you have to provide as much details as you can, if you want to get help 🙂
    zoser1-VisitorAuthor
    - I am trying to run Creo PArametric and Creo Simulate 3 and 4
    - all are Student versions
    - Yes, the Software are installed
    - I'm not connected to a PDM system
    -OR-
    Case 1.]
    graphics  win32_gdi
    Case 2.]
    What builds are you trying to run on Windows 10?
    Student or Production versions?
    Does the software install?
    Are you connected to a PDM system?
    What happens when you try to start them?
    - Student versions
    - NO, I'm not connected
    - It seems that the program is to start, then nothing
