Jan 13, 2010 8:32 AM UTC
Save a Copy
Hi When you go to Save A Copy,you get some File Directory shortcuts at the top,how do I go about to add my own Directories in there. Thanx Rene
    Jan 13, 2010 11:18 AM UTC
    can you clarify or explain what is your problem ...
    Jan 14, 2010 4:58 AM UTC
    If you want to make a new directory just right click inside the 'save a copy' window to make the new directory. If you want to choose a directory to save the file, choose the directory in the common folder to change the current directory in which proe will save your file. Does that answer your query?
    Jan 14, 2010 6:20 AM UTC
    I want to make a new directory in the "Save a Copy" window where it shows those small directory icons If I right click inside that window nothing comes up. Am I missing something?
