Saving a copy of an assembly with suppressed components
- 4 replies
- 3499 views
- Translate All
We have a modular sub-assembly (called CM1) in our library with many options (assembly/part/feature groups) that may be suppressed or unsuppressed via parameters and PRO/Program. The sub-assembly parts have a CM1_ prefix. I want to be able to copy this sub-assembly multiple times (CM2, CM3, etc) and be able to use different options for each one.
First I copy CM1 from our library into a job folder (so all of the initially suppressed parts come with it). Then I use "Save a Copy" to create CM2, CM3, etc and rename sub components. The problem is that Pro's "Save A Copy" feature doesn't include suppressed parts, so when I try to enable a suppressed option in CM2, it pulls the CM1_ part instead. I can clear my memory, open CM2, and rename the CM1_ parts, but I really would like the process to be automated to reduce errors.
Can anyone see a way to do this? I'm using Wildfire 3.
