Sep 1, 2014 8:24 AM UTC
Saving Part File from Creo 2.0 to Pro/E 4.0
Is this possible?
Sep 1, 2014 5:18 PM UTC
Sure, if you don't mind saving the Creo 2.0 part as a STEP file and importing back into WF4.
There is a tool known as Granite that is suppose to "help" with this, but it too looses a lot of intelligence.
Maybe Pro/Program can help?
Sep 1, 2014 6:06 PM UTC
I'm not sure Granite would work, if I remember correctly Granite "plugin" operates only on two versions back, so in WF4 you can open files up to Creo 1.0. You can open Creo 2.0 files back to WF5. At least that's what documentation for Granite kernel for Pro/E / Creo said last time checked it. It might work, of course, but it doesn't have to.
Your remark on Pro/Program got me thinking if it would be possible to save program from Creo 2.0 and use it to build part in WF4, I'll try to check it tomorrow at work because I'm curious myself now
Anyway usually the easiest (and most probably the only) way is unfortunately to use STEP/IGES to transfer geometry and loose all the parametricality in the model.
Sep 2, 2014 2:52 AM UTC
That was very obvious. And it is also obvious that I didn't make myself clear.
I wanted to save a Creo part file to Pro/E with all its history attached. And I can easily do the editing of the file.
Is that possible?
2-Explorer
Sep 2, 2014 2:57 AM UTC
Contact PTC and see how much they will charge to do this.
Otherwise it is not possible.
