Sep 6, 2016 6:20 PM UTC
Saving structure
We use the basic file system to save/store our CREO data, not with Windchill. One thing I started to notice was CREO would make multiple save files, all with the same name but ending in a number in a sequence.
Why does CREO make a new assembly file to save the data? Is there a way to turn this off?
If I go and open a file in CREO, the ASM won't show with any numbers. Is this a storage versioning feature that CREO automatically does?
Thanks for any input,
Jason Brehmer.
StephenW
Sep 6, 2016 8:25 PM UTC
It's simply a version #. At any time, if you find a corrupted file or made a mistake in a model and want to revert to a previously saved version, you can remove versions and re-open the model.
As of Creo 3, PTC now offers a way to turn this off. SAVE_FILE_ITERATIONS NO
I suggest learning to use the iterations. They saved me many many times and many hours of work.
Once a project is complete, use the purge command to delete old iterations.
jbrehmer4-ParticipantAuthor
Sep 6, 2016 8:31 PM UTC
Thanks so much again Stephen. I'll try this out and make note of it.
What is the purge command and where can I find it?
StephenW
Sep 7, 2016 10:46 AM UTC
purge.bat is a file in your <loadpoint>\Parametric\bin folder (ex: C:\Program Files\PTC\Creo 3.0\M070\Parametric\bin
Better yet, there are some free online programs, specifically spekan purge (Software download) that is highly customizable. This is the thread that shows what it looks like Re: Spekan Purge Tool
Purge.bat, when you run it in a folder that has creo objects with multiple versions, will remove all the versions except the latest.
There is also a file by file purge http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/fundamentals/fund_two_sub/To_Delete_Old_Versions_o…
