scale 1:1 as default
  • May 8, 2015
  • 2207 views
hello people
i make a model part in creo , and when i create drawing fille , creo transform my drawing depending on format template
i want always 1:1
it is posible a setting in config . pro
tks
KenFarley
In your config.pro, you can set a parameter to make the default scale for drawings. Not surprisingly, it's called
default_draw_scale
Set it to a number, in your case 1.0, and, according to the documentation:
"Sets the default drawing scale for views added with the No Scale command. The value must be greater than 0. No - The system does not set a default drawing scale."
The default value is -1, which does nothing and allows Creo to calculate the scale based upon model size, etc.
