Apr 12, 2011 12:22 PM UTC
Screen Resolution / jagged lines
HI Everyone
I upgraded my pc and now when I have models open on my new pc the lines look jagged and not smooth at all,is there a setting somewhere I have to change or any ideas from your side,the graphics card is a NVIDIA Quadro FX 580(latest driver is installed),monitor is a 26" lcd (resolution set to 1360x768)
Previous set up was a NVIDIA GEFORCE 8500 gt with 15" screen.
I am attaching a screen shot,hope you can see the lines,any help will be appreciated
Thank you
Rene
Apr 12, 2011 1:01 PM UTC
Hi Rene.
Seem to be enough to increase the resolution. Your standard resolution (1360x768) is suitable for smaller screens and not on "26"
Vladimir
Apr 12, 2011 1:21 PM UTC
Hi Valdimir
So you say I have to increase the resolution? At the moment I cant choose higher than (1360x768),so how would I go about to do this.
Thx
Apr 12, 2011 1:29 PM UTC
Rene,
You might try going into View/Display Settings/Model Display, then select the Edge/Line tab and set Edge Quality to High or Very High. If that works, you could create a mapkey to make it easier to get there.
Tim
Apr 12, 2011 1:55 PM UTC
HI Tim
Thanx,but I did that and set the shade quality to 10,but does not fix my problem
Rene
Apr 12, 2011 9:21 PM UTC
Your pixel size is 0.42mm - maybe thats your problem.
Apr 13, 2011 5:08 AM UTC
Hi
Could my problem be that I am running a dvi cable from graphics card through a adapter and a vga cable into the screen?
Apr 13, 2011 1:45 PM UTC
Hi All
Thanx for the input.
I exchanged my lcd screen today for a full hd led screen,which resolution can be adjusted higher than 1360x766,so hopefully that will be the solution to my problems.
Cheers
Rene
Apr 14, 2011 5:18 AM UTC
Hi Rene.
You are welcome
I'm glad that increase the resolution helped
Have a nice day.
Vladimir
