Mar 6, 2016 7:19 AM UTC
Scrolling issues! Can't rotate or pan. Please help.
I have Creo 3.0 M010 on Win. 10. In order to scroll, I have to press control or else it won't scroll. Second, I can't rotate or pan at all. I have tried with just my touchpad and my wireless Anker mouse. I can live with having to press ctrl while I scroll - but I need to be able to rotate/pan my models! Any help please? Also, I have set my inactive windows settings to "off".
ropitzAnswer
Mar 7, 2016 3:17 PM UTC
Hi Peter,
try to set up the wheel of your mouse in the system control of Windows. It might be set to the wrong option. In most of the drivers it should be set to "Middle mouse button" and not to "Wheel mouse". The correct names of options depend on your Windows and on the driver versions. But sure you will be able to find a setting that fits. Just try some out to find the right one. Otherwise contact your IT and ask for an adequate driver.
Good Luck, Ruediger
ropitz10-MarbleAnswer
Hi Peter,
Good Luck, Ruediger
psingh-91-VisitorAuthor
Mar 7, 2016 5:36 PM UTC
This worked! Thank you so much. Now, do you know why I have to hold down ctrl to zoom in and out with my mouse?
Mahesh_Sharma
22-Sapphire I
Mar 7, 2016 9:55 PM UTC
Hi Peter,
Please mark reply to post from Ruediger as correct answer as that work for you.
Mar 8, 2016 8:47 AM UTC
Hi Peter,
I am sorry but I don't know why you have to hold the Ctrl key. You might have a very strange mouse with multifunktional buttons or something like that 🙂 Somtimes in the settings you can find how to match the middle mouse button to certain programs, in this case to Creo. I saw this once in the settings of a space mouse. Usually there should be any setting to get it fixed. Good luck again, Ruediger
Mar 8, 2016 9:15 AM UTC
It's because Creo 3.0 M010 is not supported on Windows 10 and Microsoft have made some changes to mouse behavior in Win10. Here you can find a discussion with workaround to make zooming with scroll possible:How to make scroll wheel zoom work in Windows 10 with Creo Parametric
