2-Explorer
March 27, 2015
Set Creo 2.0 browser to Mozilla, but IE keeps loading
  • March 27, 2015
  • 6 replies
  • 4429 views
Hi Folks,
I set my option "windows_browser_type" to "mozilla_based_browser", but IE still loads. The option does not have the red circle slash in the config editor so it seems to have loaded. I do not see any other conflicting options. Firefox is installed, but I believe Creo uses its' own code anyway. Any ideas?
Creo 2.0 M100
Mark
Hey Mark, did you check to see if you have multiple config.pro files loading that would overwrite to one you are changing?
mganzer2-ExplorerAuthor
2-Explorer
March 27, 2015
Hi Andy,
Yes. I checked the load-point config.pro & config.sup, as well as my own config.pro. I also checked the options tools in Creo and set it to show all options for the session. The only thing I can think of is I had set the option to limit IE to 9 functionality. That is no longer set, but I wonder if that set an internal flag someplace that is not letting go.
Hmm. The only other thing I can think of is to wipe the cache location.
C:\Users\%username%\appdata\roaming\PTC
In here would be both your workspace cache as well as some other items. you can backup the PTC folder and then try deleting this and see if that helps.
Mark,
Creo does not use Firefox installed in Windows. It uses its own special version of Firefox located in MOZILLA directory.
Look into:
Creo2_LOADPOINT\Creo 2.0\Common Files\M100\i486_nt\obj\MOZILLA
-OR-
Creo2_LOADPOINT\Creo 2.0\Common Files\M100\x86e_win64\obj\MOZILLA
If I set "windows_browser_type" option to "mozilla_based_browser" and launch Creo, then I can see running process ptc_win_gecko_server.exe in Task Manager.
Martin Hanak
2-Explorer
April 1, 2015
Near as I can figure it is invoking Mozilla (ptc_win_gecko_server.exe in process). The login to Windchill is of a Mozilla type as well. Seems Creo is not bothering to switch the browser icon from IE to a Mozilla icon. Long story short is that it appears that Mozilla is running but there's no way to be sure.
hi,
try putting this link into your Creo browser adress bar
http://whichbrowser.net/
