Set default drawing frame in Creo 3.0
Hi everyone,
by starting a new drawing, I try to set a preselected drawing frame. Until now there appears a table of all possible formats. It is very costly to change the frame always manually. Do you have an idea where I can change the default settings in the config (for instance preselect an A3 format).
I´m still a beginner in Creo 3.0
Thanks at all
Justus
18-Opal
May 8, 2017
Hi Justus,
You can create a drawing template file, which uses the A3 format file.  Then set the config option template_drawing to point to the template drawing file.
Amit
