Jan 28, 2011 12:12 AM UTC
set environment variables on ProE Startup?
I know I can set the location of the PDMLink cache folder in the startup script.
I want to set some other environment variables during startup.
We have some diskless machines and I don't want to have these variables hard coded into the disk image. (I have to rely on IT to change that, only happens every three months.)
I can set the cache folder like this:
set PTC_WF_ROOT=%USERPROFILE%\pro\wf4_maintence_test\PDMLink_Cache\PTC\ProENGINEER
What I need to do is set the path to the ProE install bin directory.
If ProE is installed locally the following paths get added to the system global paths:
P:\wf4-m170\proeWildfire 4.0\bin
P:\wf4-m170\proeWildfire 4.0\mech\bin
Anyone know the syntax to do this?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
davehaigh13-AquamarineAuthor
Jan 28, 2011 12:16 AM UTC
I think I found the answer. Still need to test it out.
set PATH=%PATH%;"P:\new\path\one";"P:\new\path\two"
David Haigh
Jan 28, 2011 12:23 AM UTC
Tested it out. It works.
David Haigh
Jan 28, 2011 12:24 AM UTC
David Haigh
