Jun 2, 2015 2:04 PM UTC
Sett Default Surface Color
Creo 2, M120
In a model that hasn't been assigned a color, surfaces appear a lavender color while solid geometry is light grey.
Is there any config setting to define what the default surface color is?  I'd like to apply some transparency.
Chris3
Jun 2, 2015 2:10 PM UTC
If you are using start parts you can set the color in your start part.
Jun 2, 2015 2:32 PM UTC
For surfaces only?  How?  It doesn't appear in the list of colors in the model and I cannot seem to copy it from the model.
Chris3
Jun 2, 2015 2:45 PM UTC
Sorry I read your question too quickly. I am not sure how to do it for surfaces only.
Jun 3, 2015 6:27 PM UTC
This is brilliant, thank you.
What's even better is that it applies to existing models where there was no explicit colors assigned.
Jun 5, 2015 3:58 PM UTC
I was really hoping to find the default skeleton model color in there too, but it doesn't seem to be. Any idea where that one is hiding?
Jun 5, 2015 4:17 PM UTC
Doug,
did you try SKELETON_MODEL_DEFAULT_COLOR config.pro option to set skeleton color ?
See To Create a Display Color for Skeleton Models
Martin Hanak
Jun 5, 2015 6:55 PM UTC
Yep, in fact I posted a thread about this a while ago.  What I want to do is make all my skeletons 75% transparent.  That option lets you set the color only, the method above lets you control everything about the default color used.
Jun 8, 2015 12:37 PM UTC
If my understanding is right, you are trying to change the color of a particular surface of a part.
a. Open the desired part.
b. Click on the appearance gallery drop down arrow.
c. Select a color, for example 01_transparent_gelb.
d. Click on the surface for which you want to change the color.
e. Then click the middle mouse button to exit the command.
I tried this in Creo 3.0, works fine . Please give it a try.
Best regards,
Prasanna Simha T.R
