Jul 15, 2010 6:36 PM UTC
Setting config and .dtl options in WF3
Last time I used Pro/E it was Rev 200i or something. I want to set up a
workstation with Wildfire 3 and was wondering if setting up the config.pro
and drawing.dtl files is still the same. We used to define the path to the
.dtl file in config.pro in ye olde days and put the config.pro file in the
startup folder.
Is this still the same? Can I use my old copies of config.pro and
drawing.dtl that I hade all nicely set up with the old Pro/E, or do I have
to start all over?
Thanks for any advice,
pra@ara
Jul 16, 2010 7:18 AM UTC
Basically, it's the same.
Some parameters and options have changed, of course...
