Settings to show inserted image
I've inserted an image into a model. but all I get is a gray square. Obviously I'm missing some important settings. What are they? The image is a jpeg
in my CR2 M070 images in model are displayed correctly. See attached data.
MH
davehaigh13-AquamarineAuthor
Nope, I still get gray rectangles.
last idea ...
  • eliminate config.pro files
  • test graphics win32_gdi option
MH
It's been a while since I ran into this - I remember that within windows, there is a place to set the default extension for image files - if it is not set to the correct extension, you will get just a box (this usually happened in drawings.)
Maybe that will give you a clue to what is happening.
Mahesh_Sharma
22-Sapphire I
February 10, 2016
David,
Generally this happens when data is unable to locate the image file and it will report message Could not locate image:<image name>".
As a trail save the images in one folder and set the config option search_path with value as folder location. Create a new part, insert image and test that.
