Sheet metal, wall creation, give constraint and edit.
I am using Creo Parametric Release 6.0 and Datecode6.0.0.0
Hi there, I need some help with answering some questions so our customer is able to use his sheet metal tools properly in Creo.
> Our customer tries to add multiple flat walls or flanges to a primary wall and he can do just one at a time.
We would like to know what is the reason behind. And how to resolve it.
> Also we have another few Questions how to give constrain to selected flat walls so they behave the same way when we are editing them.
> How we bend or flatten individual flat walls or flanges.
I am looking forward to hearing back from you.
Kind regards,
Felician
Here are the errors that I faced
N/A
    tbraxton
    tbraxton
    It is often faster to model a solid part and then convert it to a sheet metal part.
    To Convert a Solid Part into a Sheet Metal Part (ptc.com)
    Dale_Rosema
    Also remember that sheet metal parts have to have constant thickness.
