Feb 3, 2014 3:31 PM UTC
Show Model Annotations default setting...
I am on Creo 2, date code M030. I searched around a bit, even here, and couldn't find where to set the show model annotations default behavior to "SHOW NONE".Seems like out of the box it's set to "SHOW ALL", and I find myselfconsistentlyhaving to switch this to "SHOW NONE". (That's the right button under the list of show items in the popup.) This used to be an issue with WF, then PTC relented and gave us a config option to set the behavior. Hopefully, they did not "loose" this...
thanks in advance...
Feb 3, 2014 3:58 PM UTC
There is the "display_annotations" config option have you checked that? Looks like the default is yes.
Feb 3, 2014 7:27 PM UTC
Paul,
I am sure that they (PTC) did not lose that option.
Michael P. Locascio
3-Newcomer
Apr 4, 2016 3:18 PM UTC
Paul - Did this advice solve your query as I'm trying the figure out the same question with Creo3.
"display_annotations" config option NO isn't working for me
StephenW
Apr 4, 2016 6:19 PM UTC
Maybe you are thinking show_preview_default and the setting should be REMOVE
3-Newcomer
Apr 5, 2016 7:49 AM UTC
I've checked and this setting is already set to "remove *"
