Show tooltips when hovering over icons
How do I enable tooltips next to the cursor when I hover over an icon? My system only shows them by the message area, which is counter-intuitive to me since the other dozen or so programs I use daily display them next to the cursor.
Using Creo 5.0.0
Using Creo 5.0.0
add following option into config.pro file.
ENABLE_POPUP_HELP   YES
Using Creo 5.0.0
JTebbe1-VisitorAuthor
Thanks, @MartinHanak
For anyone else who wants this feature, the solution seemed to required a restart of CREO.
Dale_Rosema
FYI: typically all changes to your config.pro require a restart. Especially if you edit the config.pro outside of Creo.
