May 13, 2015 8:43 PM UTC
Silent Uninstallation of PTC Portmapper
Wanting to know if this uninstall can be made quiet no user prompts. I have tried the following command line switches
C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe /silent
C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe /quiet
May 14, 2015 4:33 PM UTC
Creo 2.0 can be uninstalled using following command
C:\Program Files (x86)\PTC\Creo 2.0\Parametric\bin\uninstall.exe –quiet
See https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS127329
You can try C:\Program Files\PTC\PTC Portmapper\bin\uninstall.exe –quiet
Or you can contact PTC Support as last instance ...
Martin Hanak
May 14, 2015 4:00 PM UTC
David,
I am just curious.... Why did you install PTC Portmapper ?
Martin Hanak
dachammer1-VisitorAuthor
May 14, 2015 4:10 PM UTC
I am unsure as to why it was installed. It wasn't something I specifically installed must have came in with something else that was selected during our install.
May 14, 2015 4:14 PM UTC
According to my knowledge, PTC Portmapper is necessary to install when user uses CADDS5 system. So uninstall it using Windows UI and never install again.
May 14, 2015 4:36 PM UTC
I don't have the uninstall for the PTC Portmapper however I have used the following for other PTC components. I think it would be similar to the Parametric and Simulate removal commands:
start /w "" "%UNINSTALLPATH%" -quiet
Here is code from my Creo installer that removes the old stuff
echo Starting removal of Creo Platform...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\creoagent_32_64.msi" /q
rem sleep 5 seconds (5 pings at 1000 milliseconds per ping)
ping 127.0.0.1 -n 5 -w 1000 > NUL
echo Starting removal of Thumbnail Viewer...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\Thumbviewer_32_64.msi" /q
echo Starting removal of Product View 9.0...>>%LOG%
start /w msiexec.exe /x{C2727593-C9AF-41E0-99C6-B004393564A1} /q
echo Starting removal of Creo View Express...>>%LOG%
start /w msiexec.exe /x "C:\ptc\Creo 2.0\Common Files\%OLDBUILD%\install\addon\pvx32_64\pvexpress\CreoView_Express_32_64.msi" /q
echo Starting removal of Arbortext IsoView 7.3...>>%LOG%
start /w msiexec.exe /x {DE52A69A-978A-480A-82F7-E17C50F98EC6} /q
echo Starting removal of Creo Quality Agent...>>%LOG%
start /w msiexec.exe /x {5B7F8A19-AF71-4517-B49C-683AFC5B639C} /q
(set PARAMETRICPATH=C:\ptc\Creo 2.0\Parametric\bin\uninstall.exe)
(set SIMULATEPATH=C:\ptc\Creo 2.0\Simulate\bin\uninstall.exe)
echo Starting removal of Creo Parametric...>>%LOG%
start /w "" "%PARAMETRICPATH%" -quiet
rem sleep 20 seconds (20 pings at 1000 milliseconds per ping) - required to prevent error
ping 127.0.0.1 -n 20 -w 1000 > NUL
echo Starting removal of Creo Simulate...>>%LOG%
start /w "" "%SIMULATEPATH%" -quiet
May 15, 2015 2:00 PM UTC
Thank you great information!
