Jul 25, 2014 1:23 PM UTC
Sketcher config.pro option don't work ?
I have try to set this option to YES :
sketcher_auto_create_references
But it looks to have no impact on the behavior of the sketcher.
I mean, for example, if I select the face of a cube with a hole inside,
then I go to the sketcher, the only automatic references I've got are the 2 references planes as usual.
I had imagined I will obtain the whole contour of the face selected as references.
Have you try this option ?
Jul 25, 2014 2:08 PM UTC
Try sketcher_auto_create_references 2
I believe you just need to add a number quantity instead of yes or no
Aug 21, 2014 1:41 PM UTC
tested, it's don't works.
Jul 28, 2014 5:47 PM UTC
There are two options that are quite similar:
"sketcher_auto_create_references" with a default of "no" - (This option controls the automatic reference creation from selected background geometry.)
and
"sketcher_auto_create_refs" with a default of "2" - (The option values are: 2: the system automatically creates 2 dimensioning references; 1: the system automatically adds the orientation reference as a dimensioning reference; 0: the system does not automatically create dimensioning references.)
