Slower to open models straight from creo in a brand new empty workspace, than to add to workspace then open
Since upgrading from Windchill 9 to 10, we have noticed that it is considerably slower to open models straight from creo, in a brand new empty workspace than to add to workspace then open.
Our models can be 20k+ parts, so we tend to use reps, which is why we want to add models by opening through Creo, instead of adding all to a workspace and causing that to crawl (20+ minutes), as this will only add the model required for that Rep.
Is there a setting we can change that could be related to this or a reason why we are seeing this issue?
Thanks in advance
    Opening any file directly in Creo will be slower as you are just doing the download behind the scenes instead of directly ahead of time.
    tallen1-VisitorAuthor
    It always seemed quicker to open the models in earlier versions, as long as you know the exact filename, from Creo than to go through the rigmarole of adding to a workspace and then opening the drawing.  Adding to the workspace first adds 20K+ parts to it, that only needs 3K+ parts for a particular drawing and then all the impacts of opening the workspace, even with filters active (have had to wait over 20 minutes in some instances) to cut down on the number items displayed.
    I was hoping that there is a setting that could be changed / tweeked that would help the situation?
    2-Explorer
    April 3, 2017
    If you are getting too many parts that aren't related, look at the options. It can be set up so that when an assembly is added it will also add all the drawings of the parts and any other parts that are also on those drawings, cascading into a huge mess.
    What used to make opening the workspace go faster was to eliminate information columns; anything that requires information from Windchill such as Compare Status and such. Filters are probably applied after getting all the information for all the parts and may do no good to change the amount of talk between the client and the server.
    Try making a view of only the filename column and see if that is quicker.
