Small window to edit value opens and closes immediately in sketch module of 3D part
I am using Creo Parametric Release 7.0 and Datecode7.0.8.0
Since today, in the sketch module of 3D part, when I want to edit a value, the window to edit opens and closes immediately.
I tried to restart my station, create a new part and change the CREO version but this problem persists.
I had a problem with my config file. In order to locate the problem, I suppressed my file and I restart the software. After, I opened this file and I suppressed paragraph step by step to find which one had a problem.
NB_104624201-VisitorAuthorAnswer
3-Newcomer
What was the config setting that caused the problem, mine has just started doing this but the config.pro file hasn't changed in weeks.
