Apr 4, 2013 7:37 PM UTC
software push...
hello all. Upgrading to Creo 2.0 and would like to know the difference bewteen Wildfire 5.0 and Creo 2.0, if any. Thanks, Justin
    Apr 4, 2013 9:22 PM UTC
    True wilfire 5 or the 1st implementation of the ribbon?
    If the former: be prepared to post on all the "we hate ribbon" posts...
    If the ladder: all your bugs are fixed.
    Apr 5, 2013 5:23 AM UTC
    Hi Justin,
    Recently i also upgarded to creo 2.0, compared to ProE/WF 5.0 Creo have some additional user interface on ribbon.
    • In Render some additional rooms are given, that looks amazing for photo relaistic rendering.
    • Measure tool for measuring various geometry is good.
    • Annotate Ribbon is also good
    • Ribbon, hotkeys, and environment settings for configuring your workspace to your preferences.
    • Embedded command finder for quickly locating capabilities when you need them.
    • Intuitive 3D dragger, in-graphics toolbar, and mini toolbars for more efficient designing.
    • Use track changes capabilities to see exactly what has been modified within an assembly.
    • Work more quickly with streamlined new component placement constraints.
    • Save time and improve system performance by loading assemblies as Light Graphics representations.
    • Have more control with four new constraint types (normal constraints for surfaces, distance, angle offset, and normal constraints for points and lines).
    • Animate exploded and unexploded sequences.
    for me Initially Ribbon interface is very hard...now it seems very easy
    Vinoth
    Apr 5, 2013 5:37 AM UTC
    UNLOCK POTENTIAL with Creo Parametric 2.0 - Top 10 Reasons to Upgrade to Creo Parametric.pdf
