20-Turquoise
Jun 27, 2014 10:24 PM UTC
[solutions] - Feel like I've been living under a rock - Network installation of Creo 2.0 not su
On 06/27/14 14:05, Villanueva, Antonio UTAS wrote:
> Ok, just moved to Creo 2.0 and we've tried experimenting with installing Creo as a mapped network
> application.
That still works good with the exception that Creo 2.0 will install (locally) Creo Platform and Creo
Thumbnail Viewer (as you have already discovered).
> This is preferred when users lack administrative rights and you have limited IT staff. Great.
> Installs ok. Starts up, seems to work fine. There are number of little issues with the extra apps
> it tries to install on startup but those are minor. Ok, let's connect to PDMLink and start
> working. Wait where did server registry go???
> Short summary -- if you do not install the Creo Agent (Creo Platform), you cannot save the server
> registry. Lost when you shut down.
> https://www.ptc.com/appserver/cs/view/spr.jsp?n=2157073
> CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC
> Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do
> not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return
> e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation
> is greatly appreciated.
