May 13, 2010 9:50 PM UTC
Space Navigator Driver installation disables Undo
I have installed the drivers for the 3D Connexion Space Navigator on multiple machines and it disabled the Undo option in Pro/E (in 3D modeling not in the sketch tool) as soon as I uninstall the drivers the Undo option comes back. Anyone else run into this? Suggestions?
Colleen
May 14, 2010 11:46 AM UTC
Greetings...
It's a "known" issue that was recently discussed on the forum. I'll forward the thread to you so you can see the details...
Mark
May 14, 2010 11:59 AM UTC
Hi Colleen
Check out this thread - the solution to remove the .dat file worked for me and I still have the 3D Connexion functionality.
http://portal.ptcuser.org/p/fo/st/thread=42533
Ryan
May 17, 2010 4:59 PM UTC
Thanks for the help. Removing the .dat file solved the issue. I'm not sure why the previous thread didn't show up in my original search but I appreciate all the responses.
Colleen
