Apr 15, 2010 12:43 PM UTC
Specifying License Priority
We have two different Pro/E license levels - Advanced XE and Enterprise SE.
We noticed that the license server starts issuing Advanced XE licenses first, and doesn't start issuing Enterprise SE licenses until all Advanced XE licenses are used. This has caused problems a couple of times because we occasionally need one of the add-ons in Enterprise SE that we don't have with Advanced XE.
How can I configure the license server to prioritize issuing Enterprise SE licenses ahead of the Advanced XE licenses?
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
Apr 15, 2010 1:08 PM UTC
Andrew,
Run PTC setup and then under create or modify commands you can create
new commands to pick up different licences or modify you existing
command so that the order is different.
Regards
Iain
Iain Lewis
Principal Application Specialist
iCentre UK
PTC
+44 (0) 7753 915635
