Spekan sBatch Troubles
- 2 replies
- 1563 views
- Translate All
Hello all,
I am new to the Spekan sBatch tool (version 4.1) and was hoping some of you veterans might be able to help me out.
As a simple test, I tried to do the following:
-Use a .prt on my desktop to run a simple action on
-Have the tool write a mapkey that I can load into Creo
I can generate the spekan.pro file without issue, and I can load it into Creo as well. When I look at my mapkeys in creo, I show four additional mapkeys that were loaded in from the spekan.pro file:
-batchclose
-batchexit
-batchsave
-run
These are in addition to my mapkeys in my config file loaded during creo startup.
However, when I excecute the "-run" mapkey, nothing happens. The message area in Creo says "Playing mapkey -run...".
Any ideas as to what might be wrong?
Also, I noticed the tool produces the spekan.pro file AND another file called sBatch.pro. What is this file used for?
I have attached my spekan.pro file.
Andri
Creo 1.0 M050
Windchill 10.0 M030
