Apr 10, 2015 8:02 PM UTC
Start Parts
I have the start parts defined in the global config.pro (see below copied from config)
start_model_dir S:\ProE\ProE_custom\templates
template_designasm mmks_assembly.asm
template_sheetmetalpart mmks_part_sheetmetal.prt
template_solidpart mmks_part_solid.prt
The solid parts work but the assembly start part does not. I just double checked the filename spelling and it is not corrupt. Any clue why it might not be working?
nhanrattyAnswer
Apr 12, 2015 4:46 PM UTC
Bryan
Does your assembly template file have the Creo version number in it's name, i.e. mmks_assembly.asm.1?
Remember you might need to turn on the option in Windows so that you can see file extensions when looking at them in Windows Explorer.
I know for the start files we use I include the version number in the config.pro option.
Neal
2-Explorer
Apr 10, 2015 8:07 PM UTC
The config options document recommends "Specifies the designated template assembly. Use full path to avoid problems." for template_designasm, but does not say the same for the other template options.
Apr 10, 2015 8:59 PM UTC
I use the full path for my template files.
template_designasm x:\ptc_settings\templates\assembly.asm
template_solidpart x:\ptc_settings\templates\solidpart.prt
etc
Apr 11, 2015 2:07 PM UTC
OK. I used the full path in the global config.pro and it did not work. However, it did work in my local config.pro. What's the deal with that?
StephenW
Apr 11, 2015 2:26 PM UTC
Are you sure the global config.pro is loading? Also, if any config is loading after the global and it also specifies the start part location, the last one loaded will win.
nhanratty1-VisitorAnswer
Bryan
Neal
Apr 13, 2015 12:51 PM UTC
Thanks Neal!
That did the trick, perhaps in combination with the full path.
Bryan
