Starting in a project folder
For many years, I'm using Creo (Pro/E) on local HDD.
In each folder project, I had a .cmd script that launch Creo 2, 3...)
So, local config.pro, appearances were loads for each project, depending on my clients.
Now, I can't do this with Creo8.
Batch (cmd) files doesn't works anymore.
So, what could be a good solution for starting Creo in a specific folder, loading global AND local config.pro and could open local files ?
Now, Opening file start-up in "My Documents"...
Thanks a lot.
@Dom_CHENTRE wrote:
Thanks a lot.
For Creo2, for example, I had a cmd file with this :
start "creo" "C:\Ptc\Creo 2.0\Parametric\bin\parametric.bat"
So, When I clicked on cmd file, Config.pro and other local files were loads.
Now, doing the same with Creo8, default loading file is not local folder but "My Documents".
I created start.bat in E:\users\creo8_parametric directory. The file contains following line
start "creo" "E:\PTC\Creo8_020\Creo 8.0.2.0\Parametric\bin\parametric.bat"
When I run start.bat it loads config.pro located in E:\users\creo8_parametric directory successfully.
So it seems to me that you have some mistake in your bat-file.
Do you need the ability to run different versions of Creo depending on your client or will all of your work be done in Creo 8?
If all work in a single version of Creo, depending on client, I would just create a shortcut in your folder to the parameytric.bat file in each version /bin folder and then set the Start In setting to that folder.
I use a command file to copy and launch project config files and different versions of Creo with Creo 4 and 7. Don't know why anything would change with Creo 8.
Thanks a lot.
What is the Start In set to on your command file for Creo 8?
Mine is set to:
