Mar 12, 2013 8:05 PM UTC
Starting problem
Hi all
would you like please help me to tell why CREO doesnt get started after installing it properly.It just give a busy symbol for 3 seconds and disappears.It was working fine before i reinstalled it.PC specs and graphics are fine and it was working fine.but doesnt works now.i dont know why.
Mar 13, 2013 2:05 AM UTC
It is difficult to tell. There are subtle differences in how the program is installed. I always start from scratch leaving only the license manager in place and removing all the other programs in windows. The I donwload the whole file from the download site and extract the install files in separate folders (Creo and Help). From there I process the install.
If you continue to have trouble, please contact Customer Service and log a case with high urgency. They will call you back and walk you through the install. It will be best if you have the install files already downloaded.
DavidKhan1-VisitorAuthor
Mar 13, 2013 6:54 PM UTC
yea.i have tried the general method and it works always.but it doesnot works now.
Dale_Rosema
Mar 13, 2013 7:13 PM UTC
Even if it is an upgrade, I don't try to attempt it without my VAR on the line. I run into to many things that even confound them to try and figure out how to know to do it myself.
