Stop Creo from pulling fonts off C:\.............?
I currently have our config.pro file set up to pull fonts from a particular drive location, Creo continues to bring up fonts that are located in the C:\Program Files\PTC\Creo 3.0\M050\Common Files\text\fonts location of individual machines.  Is there any way to stop creo from lookign at the fonts folder on individual machines?  I would like all users to pull from the same location.
TomU
TomUAnswer
Rename the folder on C (or just delete the files).
TomU
TomU23-Emerald IVAnswer
sbender1-VisitorAuthor
Yes both of your suggestions worked, what we ended up doing was placing unique fonts in the server location call out in the config.pro and leaving all the fonts that are loaded with Creo in the C:\ location.
Thanks!
Set the config option : pro_font_dir
you can set it to a server dir, perhaps this will do the trick
ES
