Suggestion required - Speed test
I need help/information/suggestionon server connection speed test.
We have a server from which we access intralink/proe files. This server is at a country X. And we work from two other countries Y and Z. We would like to compare the time consumed on checking and checking out the intralink proe files from Y location with that of Z location.
As of now we are just taking couple of large assembly files and checking the time on crude method (actually doing checkin/checkout at both locations for same file).
Is doing a speed/bandwidth test from both locations (pinging server IP at X location) a good way?
Kindly requesting yourselfto throw some light on this.Which is best way to do it?
Thanks and regards,
Jnanesha KS
