Nov 9, 2011 8:06 PM UTC
Summary - Creo Leaves Command Prompt Window Open
Thanks to Ben for digging up a thread from this summer with the answer.
I vaguely remember it now, but Creo wasn't on my radar back in June so
it didn't stick.
My batch file has this now:
call "%proe_executable_folder%%proe_executable%"
It needs to be changed to:
start "Creo 1.0 Parametric" "%proe_executable_folder%%proe_executable%"
You need both parts of the 'start' statement, the descriptive bit after
'start' and the full path to the executable. I tested it and it does
work with Creo. Unfortunately, since my batch file launches WF3, WF4 &
WF5 too, I've got to figure out how to make that 'start' statement work
with them too. Creo already added 2-3 new variables to my script
because the text folder and the bin folder aren't in the same parent
folder anymore and Creo installs in a folder with the build code. Guess
I'll need one for the description too.
Doug Schaefer
Nov 9, 2011 8:13 PM UTC
I sent the summary too soon. Turns out the description doesn't matter
at all, just as long as there's something there. So this:
works just as well as this:
start " "%proe_executable_folder%%proe_executable%"
And the latter works fine with WF3, WF4 and WF5 too.
Doug Schaefer
