Sep 15, 2011 8:25 PM UTC
Summary - WF5 Appearances
- 0 replies
- 4531 views
- Translate All
I figured it out; the 'Library' section comes from the config option
'pro_texture_library'. I had thought I checked that, but I was editing
our config file for WF4, not WF5. Oops.
The appearances in WF5 are installed in:
C:\Program Files\PTC\Creo Elements\Pro5.0\graphic-library
Assuming you've accepted the default install folder, and you installed
WF5 after the name change to Creo. 😛
Doug Schaefer
Doug Schaefer
