Feb 21, 2013 3:40 PM UTC
SWX Worker configuration
Hi
We have currently configured Solidworks and Creo Parametric Workers on a single Host.
The issue is Solidworks Worker is working only in standalone mode.
If configured as a service only Creo Parametric Worker runs and Solidworks worker doesn't get started.
Is this a limitation of Solidworks .Is this the normal practice in setting up Solidworks worker.
Regards
Kiran
Feb 21, 2013 8:52 PM UTC
Separate they two. I've successfully set this up a number of times but the reality is that the publishing system is one of the most unstable portions of a normal PDMLink setup. If you put BOTH workers on one machine you are exacerbating the issue.
Also note, SW worker will require "access to the desktop" and a user login for the service if I recall correctly. PTC has a how-to on this in the knowledgebase now.
[cid:image001.gif@01CE1029.F5910AB0]
Steve Vinyard
Application Engineer
kms1-VisitorAuthor
Feb 22, 2013 2:31 PM UTC
Thanks for your suggestion Steve
We will now be separating the two
Regards
Kiran
