Jan 25, 2016 2:32 PM UTC
SYMBOL ARROW
I am adding a flag note to a drawing view but need to have an arrow point to the text I want.  The leader box is grayed out on the properties box for the custom symbol.  How do I add an arrow?  Is there a config.pro selection I need to turn on?  I tried to edit the attachment point but that does nothing.
Jan 25, 2016 2:39 PM UTC
Sounds like your custom symbol was not created with the option to allow leaders.
Can this be created with a note?
Perhaps make a new symbol that allows a leader?
dbolden1-VisitorAuthor
Jan 25, 2016 2:52 PM UTC
How do I edit the symbol file?  I can find it but cannot open it.  Our symbols and tables were created by someone who retired and I am now the admin for Creo.  I have had no administrative training with this.
Jan 25, 2016 3:27 PM UTC
Not knowing how you are set up, by default they are located at:
c:/program files/ptc/Creo X.X/Common files/<build>/symbols
When you have a drawing up, select the annotate tab
using the pull down menu of Symbol, select Symbol Gallery > Redefine > retrieve
select the symbol you wish to modify
Select the attributes you wish to define (like left leader)
continue until it's to your liking, then  OK > Done > Write
You may want to take some training....IMO
Just curious, you trying to do something like this:
