Synchronization problem between 3D parameters and Windchill CAD document attributes
I am using Creo Parametric Release 3.0 and DatecodeM190
Creo parameter properties cannot be synchronized with Windchill CAD document properties
For example, if the Creo parameter is defined as A and there is parameter B, the Windchill CAD attribute is defined as B, but the attribute synchronization on B is written in the parameter field of A, and each synchronization will be synchronized to parameter B
Translated the text from Simplified Chinese to English using google translate on 17th April 2023 at 11:53am. Translated by vnamboodheri
Subject: 3D参数与Windchill CAD文档属性同步问题
Body: I am using Creo Parametric Release 3.0 and DatecodeM190
Creo参数属性无法同步Windchill CAD文档属性
如Creo参数定义为A且存在参数B,Windchill CAD属性定义为B,但是B上属性同步写的是A的参数字段 每次同步都会同步到参数B
