Dec 4, 2014 11:01 PM UTC
The Most Used configuration options for Pro/ENGINEER and Creo Parametric
List of the most used configuration options for Pro/E and Creo
These options you can find in the installation directory (help documentation) of the software.
For example...Creo 3.0\%datacode%\Common Files\help\reference\pma\usascii\configoptions.pdf
These configuration options you can use for the application while editing your config.pro file. The most used options have a link to the description with values for the option.
Note: The options from binary code are marked as (hidden). The hidden options was found in the binary code of the application Pro/ENGINEER and Creo Parametric. The hidden options are usually provided for internal use, by the IT department of PTC during the development of new releases. Be carefull using these options, because they are unsupported, and might make your system unstable or your models corrupt.
!**********************    A    **********************
accuracy_lower_bound
add_weld_mp
afx_enabled
allow_anatomic_features
allow_move_view_with_move
allow_package_children
allow_redo_intersections
allow_rfs_default_gtols_always
ang_dim_in_screen
angular_tol_0.0
angular_tol_0.00
angular_tol_0.000
atb_show_log
auto_add_remove
auto_associate_dimensions
auto_constr_offset_tolerance
auto_regen_views
autobuildz_enabled
!**********************    B    **********************
bm_graph_tool
bom_format
browser_favorite
bump_revnum_on_retr_regen
!**********************    C    **********************
cleanup_drawing_dependencies (hidden)
cleanup_layout_dependencies (hidden)
clearance_triangulation
clr_print_plus_minus
color_windows
comp_interface_placement
comp_snap_angle_tolerance
comp_snap_dist_tolerance
compress_output_files
copy_geom_update_pre_2000i_dep
cpus_to_use
!**********************    D    **********************
datum_point_display (hidden)
def_layer
default_abs_accuracy
default_ang_dec_places
default_dec_places
default_draw_scale
default_font
default_chamfer_scheme (hidden)
default_ramp_size
delete_after_plotting
display
display_annotations
display_axes
display_coord_sys
display_full_object_path
display_planes
draw_points_in_model_units
drawing_file_editor (hidden)
drawing_setup_file
dwg_export_format
dxf_export_format
dxf_export_mapping
dxf_export_mapping_file
dxf_out_scale_views
dxf_out_stroke_text
!**********************    E    **********************
enable_absolute_accuracy
enable_component_interfaces (hidden)
enable_flat_state
enable_local_extend_variations (hidden)
!**********************    F    **********************
feature_create_auto_begin
feature_create_auto_ok
file_open_default_folder
fix_boundaries_on_import (hidden)
flip_arrow_scale
fonts_size
format_setup_file
!**********************    G    **********************
gct_enabled (hidden)
grv_default_view
gtol_dim_placement
!**********************    H    **********************
highlight_new_dims
hlr_for_quilts
hole_diameter_override
hole_parameter_file_path
!**********************    I    **********************
iconify_entire_pro
iges_in_assoc_dim_geom_21
iges_in_group_to_dwg_layer
iges_out_trim_curve_deviation
info_output_mode
initial_bend_y_factor
intf_in_blanked_entities (hidden)
intf_in_treat_polyline_as (hidden)
intf_out_asm_mapped_item
intf_out_layer
intf2d_out_cgm_ver
intf2d_out_enhanced_ents
intf3d_in_close_open_boundaries (hidden)
intf3d_out_surface_deviation
!**********************    K    **********************
kbd_cmd_abbreviation
keep_info_datums
!**********************    L    **********************
lang_propagate
let_proe_rename_pdm_objects
linear_tol
linear_tol_0.0
linear_tol_0.00
linear_tol_0.000
load_ui_customization_run_dir
lods_enabled
logical_objects (hidden)
!**********************    M    **********************
make_parameters_from_fmt_tables
mark_approximate_dims
mass_prop_update_force_change (hidden)
mdl_tree_cfg_file
model_detail_options_file
model_grid_spacing
model_note_display (hidden)
model_rename_template
modelcheck_dir
multiple_skeletons_allowed
!**********************    N    **********************
native_kbd_macros
nccheck_type
ncpost_type
new_asm_regen_revnums (hidden)
number_user_colors
!**********************    O    **********************
open_window_maximized
!**********************    P    **********************
parenthesize_ref_dim
pdf_use_pentable
pen_table_file
pen1_line_weight
plot_names
pro_colormap_path
pro_crosshatch_dir
pro_dtl_setup_dir
pro_editor_command
pro_font_dir
pro_format_dir
pro_group_dir
pro_library_dir
pro_material_dir
pro_note_dir
pro_pip_lnstk_dir
pro_plot_config_dir
pro_sheet_met_dir
pro_symbol_dir
pro_unit_length
pro_unit_mass
proe_memory_buffer_size
provide_pick_message_always
punch_axis_points
!**********************    Q    **********************
query_bin_start (hidden)
!**********************    R    **********************
raster_plot_dpi
regen_backup_directory
regen_layout_w_assem (hidden)
regenerate_read_only_objects
relat_marks_obj_modified (hidden)
rename_drawings_with_assem (hidden)
rename_drawings_with_object
reserved_menu_space
restricted_val_definition
retain_pattern_definition (hidden)
!**********************    S    **********************
save_clipped_view
save_display
save_implicitly_verified_insts (hidden)
save_instance_accelerator
save_model_display
save_triangles_flag
save_unchanged_pdm_object
search_path_file
selection_of_removed_entities
set_model_types_to_save
show_axes_for_extr_arcs
show_geom_checks_on_creation
show_shaded_edges
shrinkwrap_alert
simprep_ondemand_cleanup
sketcher_animated_modify
sketcher_blended_background
sketcher_palette_path
sketcher_refit_after_dim_modify
sketcher_starts_in_2d
sketcher_undo_reorient_view
spin_center_display
spin_control (hidden)
spin_with_orientation_center
spin_with_part_entities
start_appmgr
start_model_dir
suppress_license_loss_dialog
sym_leader_orient_move_text
symbol_instance_palette_file
system_colors_file
system_edge_high_color
!**********************    T    **********************
tangent_edge_display
template_designasm
template_sheetmetalpart
template_solidpart
terminal_command
texture
thermo_position_hint
tiff_compression
tiff_type
todays_date_note_format
tol_display
tol_mode
tolerance_class
tolerance_standard
tolerance_table_dir
topobus_enable
trail_dir
!**********************    U    **********************
use_8_plotter_pens
use_temp_dir_for_inst
!**********************    V    **********************
variable_plots_in_inches
visible_message_lines
!**********************    W    **********************
web_browser_history_days
web_browser_homepage
web_enable_javascript
web_link_file_read
web_link_file_write
web_link_proe_read
web_link_proe_write
web_max_mail_size
weld_color
weld_ui_standard
windows_scale
www_multiple_views
Best regards,
Vladimir
