18-Opal
June 21, 2012
Time to move to Creo 2.0?
  • June 21, 2012
  • 12 replies
  • 2542 views
Wondering what the wisdom is with moving to Creo 2.0 later this summer. I see by the product calendar that Creo 2.0 m020 will be out in late August. Is the product stable enough?
We would be moving from Wildfire 4.0 any thoughts on that jump?
-marc
Urgent messages: I try to limit checking email to 3-4 times per day. If you have an urgent message for me, please call or stop by.
    We're planning a move from Wildfire 4.0 to Creo 2.0 later this year: I've begun testing and preparing an install file, plus training materials. There will still be bugs like the silent install and others, but I'm going with it for 700 users eventually.
    Would be interested to hear from others on the same topic.
    Edwin
    In Reply to Marc DeBower:
    -marc
    I have to coordinate Creo with Windchill, but I may get to Creo 2 later this year.
    It depends on when I get us to Windchill 10 and what effort is needed to go on to 10.1.
    Thank you,
    Ben H. Loosli
    USEC, INC.
    We have been using Creo 1.0 since it was available for production. We currently run Creo 1.0 M030 and will move over to Creo 2.0 M010 by the end of the month.
    Creo 1.0 has given us no major problems. It has bugs here and there like all software but nothing was a show stopper for us. Moving from Creo 1 to Creo 2 will be very easy and require no training or preparation for my users. I will only create a short video with some of the new enhancements like Dynamic Cross Sections and that's it.
    Moving from WF4 to Creo 2.0 will be a much larger jump since WF5 actually had a Ribbon UI for drawing mode. You will require some training up front to get people ready for the change but I believe it will be easier than most people think. The Command Search tool in Creo is very useful and allows your users to find the commands they are looking for and learn the UI at the same time. This made our down time almost nothing and within a week everyone was loving Creo over WF5.
    The only issue we have is not something Creo 1.0 or 2.0 does incorrectly but a decision PTC made to the FEA animation process. You can no longer add multiple animation frames without calculating every step during the anaysis. We used to run an analysis and then add 15 frames to show the animation between the start and finish. If you do that now, it will run calculations for each animation frame which makes the analysis take 15 times longer than it did in WF5.
    PTC said they change this because the results were only accurate for the first and last frame, but we did not care about this. We understood the frames in the middle were only for a visual feedback of how things are moving but now we can't do this anymore. Each frame is forcing the calculations to be calculated which is a waste of time for us and I assume for many others that were using the extra frames for a visual purpose.
    Just an FYI
    "Too many people walk around like Clark Kent, because they don't realize they can Fly like Superman"
    Be aware that the requirements for the graphics OpenGL support has been changed from WF4 to Creo 2. OpenGL 3.1 must be supported. I need to upgrade hardware for 1/3 of our users due to this.
    F001 had some problems using Mozilla embedded browser with Windchill, but it is fixed in M010 as far as I have tested it.
    /Bjarne
    When switching to new hardware you might take the AMD FirePro cards into account.
    With Creo Parametric 2.0 these cards will support Order Independent Transparacny (OIT)(next to Blended and Stippled).
    This is a technique developed by PTC and AMD and enables hardware enabled transparency: extremely fast and better quality.
    AMD has exclusive rights for one year to use this technique.
    Creo Parametric 2.0 M020 should have a solution for the config.pro maintenace problem in Creo. Currently in Creo when saving the config.pro it will save all options set which are read from all the different sources ([loadpoint]\text, $HOME, startup folder). With M020 you should be able to differentiate between these files again (just like it is currently in pre-Creo).
    Kind regards,
    Olaf Corten
    Olaf Corten
    CAD/PLM Manager
    Fico B.V.
    Ratio 6, Duiven
    Phone: +31 26 3196215
    Mobile: +31 644548554
    www.besi.com
    To: Marc DeBower <->, "-" <->
    Date: 25-06-2012 07:36
    Subject: [proesys] - RE: Time to move to Creo 2.0?
    /Bjarne
    mdebower18-OpalAuthor
    18-Opal
    June 25, 2012
    Bjarne,
    Thanks for taking the time to reply. I will be posting a summary of this later this week, and so far no one has recommended against the upgrade.
    Do you know approximately how old the hardware was that you had to replace?
    -marc
    18-Opal
    June 25, 2012
    Olaf,
    Thank you for responding, we have traditionally stayed away from the AMD cards. They always had a reputation of being gamer cards, and not professional. I guess they deserve another look.
    Sounds like it is definitely worth waiting for m020, we make extensive use of the config.sup and the different sources for the config.pro.
    -marc
    18-Opal
    June 25, 2012
    Bjarne, What type of problems did you experience on the computers that required upgrading the graphics hardware? Rendering? Crashing? other?
    Thanks, Lawrence
    If the multiple config file management issue is going to be resolved
    (finally) in M020 that would be fantastic.
    I'm curious, where did you get this information? The SPR [1] as well as
    the case document [2] still shows TBD for an expected resolution
    datecode for all versions of Creo.
    [1] -
    This was discussed in a TC meeting at PlanetPTC.
    Andy Hermanson
    Engineering Design Applications
    tel 605.275.1040 x51114 mobile 605.310.8168
    website www.daktronics.com
