TomU
Mar 4, 2015 7:37 PM UTC
Toggle Layer Tree Display in Creo Parametric 3.0
Curious if anyone has figured out how to toggle between the model tree and the layer tree in Creo Parametric 3.0.
We used the following mapkey in WF3 - WF5. It worked great.
mapkey $F2 @MAPKEY_NAMEDisplay Layer Tree;@MAPKEY_LABELDisplay Layer Tree;\
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewLyrs.view`;
Creo 3 has changed the commands used to display the layer tree. So far I've been unable to figure out how to make them toggle. I would prefer to not use two separate mapkeys and/or constantly reload config files with alternate versions of the mapkey.
Thanks!
Mar 19, 2015 10:53 PM UTC
I tried several ways, just editing the mapkeys text but I haven't found a solution too...
Unfortunately, it seems that now you need to recur to something like Autoit or AutoHotKey to achieve this (maybe PTC should include them in Creo installation? ).
I think that this can be done with a batch file too:
1 - A mapkey that calls a batch file, inside the b file a variable is toggled and it writes some text to a trail file.
2 - The mapkey ends reading the trailfile.
That should do it.
Jose.
Apr 10, 2015 9:03 PM UTC
Second attempt...
I made it just with mapkeys, but still not a elegant solution.
Paste the mapkeys in your config pro and call mapkey "L".
Apr 10, 2015 10:40 PM UTC
Great!!
I made a mapkey to hide and show specific layers with just one click using the previous method. And is easy to replicate just changing the layer name in the code:
2-Explorer
Apr 10, 2015 11:26 PM UTC
Just to note - the mapkey can reload the alternate config and the alternate config can be a single mapkey. I make them text files, named for what they do, like mapkey_feature_on.txt and mapkey_feature_off.txt. Each one ends with the commands to load the other one.
Apr 11, 2015 7:15 AM UTC
Yes, I do know that.
Currently I have some working that way.
I´m just testing other methods since that mapkeys tend to stop working sometimes in some computers.
Thanks anyway.
Jose
May 18, 2016 9:03 PM UTC
My best solution until now:
mapkey $F2 %la_hide;
mapkey la_hide ~ Command `ProCmdViewLyrs`  0;\
mapkey(continued) ~ Command `ProCmdRibbonOptionsDlg` ;\
mapkey(continued) ~ Select `ribbon_options_dialog` `PageSwitcherPageList` 1 `ConfigLayout`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `ConfigLayout.AddOpt`;\
mapkey(continued) ~ Input `add_opt` `InputOpt` `mapkey`; ~ Update `add_opt` `InputOpt` `mapkey`;\
mapkey(continued) ~ Activate `add_opt` `InputOpt`;~ FocusOut `add_opt` `InputOpt`;\
mapkey(continued) ~ Update `add_opt` `EditPanel` `$F2 %la_show`;\
mapkey(continued) ~ Activate `add_opt` `EditPanel`;\
mapkey(continued) ~ Activate `ribbon_options_dialog` `OkPshBtn`;
mapkey la_show ~ Command `ProCmdViewLyrs`  1;\
mapkey(continued) ~ Update `add_opt` `EditPanel` `$F2 %la_hide`;\
It works great on my computer, and it's a more simple way.
